Hi Blagmeister,i had that too,sorry,but the ONLY way is to do a full system reset,as already mentioned.Here is how to do it,just in case you don't already know...Go to Services...then hit 4..0..1..Select
Then select option 7.... FULL SYSTEM RESET..Should take about a minute,and it will shut itself off,but do not worry,usually comes back on in about a minute or so.Hope that helps.
