Sky Plus Inputs with Communcal Dish
Discussion in 'Sky Digital TV Forum' started by dazdunne, Aug 22, 2005.
  1. dazdunne
    dazdunne
    Aug 22, 2005
    2
    I have recently had Sky + sintalled in a flat with a communal dish. I have been told that because there is only 1 input I will have to put up withe the degraded sky+ facilities. Cannot programme to record things on different channels etc..
    Does anyone know a way round this? I have heard a splitter might work to give me 2 inputs.
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Do a forum search for "Sky+ communal" - there are loads of threads on the subject.
    John
  3. fuzzb
    fuzzb
    Did the Sky engineer install this for you? If so, aren't they contracted to make sure that Sky+ works as designed, i.e. with 2 inputs?
    I am in an apartment with a communal dish with only one Sky input too, so if you could share any info you find out that would be great :)
  4. vex
    vex
    Mar 8, 2005
    2,905
    103
    London, Home Counties & North West
    +261
    The simple and unfortunate answer is NO.
    A single feed can not be made into two by splitting, it does need a seperate feed from the distribution system.
    Chris
  5. SeanT
    SeanT
    Jan 28, 2005
    6,163
    Coventry
    +368
    you can get stackers and destackers though, and I think they are available from satcure - do another search for "stacker" in here :)
  6. vex
    vex
    Mar 8, 2005
    2,905
    103
    +261
    Yes, but you still need a spare port on the distribuiton system.
    Oh and everyone I have heard of has gone back, they are currently crap.
  7. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I think a lot of the problems with stacker/destackers is with the cabling, since they work by "stacking" the output from one LNB on top of the existing LNB carrier, frequency-wise. This means that you need a cable capable of handling up to 3GHz without too much attenuation, and (sadly) many installations in blocks of flats are using cables which won't support it.
