Sky Plus In Apartment Block - Only has 1 sky feed
Discussion in 'Sky Digital TV Forum' started by rik1471, Jul 26, 2005.
  1. rik1471
    rik1471
    Jul 21, 2005
    392
    +9
    I'm due to move into my new apartment. The only problem is there's only 1 feed for sky :( - what options do I have to allow me to keep my sky plus box? Is it possible to have sky plus working from 1 feed, can I split the cable etc. etc???
    Many thanks,
    Rik.
  2. Boy Lex
    Boy Lex
    There is no way of splitting one feed... you need two feeds so either you get the landlord to supply another feed or you put your own dish up (which will probably violate the lease). Sorry.
  3. Cyril
    Cyril
    Jul 20, 2005
    1,113
    48
    +39
    It seems you might have to make do with a regular Sky box (and the superior TIVo of course :) ) and/or get a Freeview PVR , or NTL or Telewest (once again with a TiVo).
  4. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    Have a search, apparently people have set up Sky+ with just one feed - but in a limited capacity. You can still time-shift and record on the fly, but you can't record two programs at once. Also setting up a future recording involves setting up a "dummy" recording first which it will fail on, but it can be done.
  5. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,548
    The Fylde Coast
    +12,845
    You can piggy back two Sat signals on a single cable and then "split" them out. Requires non-too-cheap hardware though.
    See http://www.satcure.co.uk/accs/page1b.htm
    It may be cheaper to drag through Shotgun cable to replace the single cable if the run is not too long.
    HTH
