Sky Plus Housekeeping
Discussion in 'Sky Digital TV Forum' started by GreyMack, Sep 5, 2004.
  1. GreyMack
    GreyMack
    I have been noticing on Sky plus the percentage of hard drive that i have left is slowly diminishing, for example i have 3 items currently saved on disk 2 films of 2 hours and tv show of 1 hour so in total thats 5 hours yet it shows i only have 50% free space. Surely its 20 hours worth of space on the drive so 5 used should leave 75%.
    I've heard people mention the term housekeeping, is this something to do with reclaiming lost drive space?
    Any ideas / help would be appreciated.
  2. bobbles
    bobbles
    services 4-0-1 select
    this brings up the installers menu
    you can do a full system reset (housekeeping) this will wipe the HDD. Alternatively you can run the planner rebuild which will restore lost space without deleting recordings.
  3. GreyMack
    GreyMack
    Hey
    What am i doing wrong? as soon as i hit services (the services screen comes up) then the 4 it goes to add channels i never get to the 0 1 part.
  4. bobbles
    bobbles
    press services button on the remote
    press the number 4 on your remote
    press the number 0 on your remote
    press the number 1 on your remote
    press select on your remote
  5. GreyMack
    GreyMack
    Hey Bobbles
    I class myself a reasonably intelligent guy but that just doesn't work unless i'm doing something so stupid.
    I hit services followed by 401 all that happens is the services screen appears pressing 4 causes system set up to appear the 0 does nothing and 1 is pointless.
    Ive tried pressing them quickly and then slowly nothing works.
    I assume you have to have the remote pointing to the box for this to work?
    alright tell me im daft
  6. GreyMack
    GreyMack
    Dont say a word I'm daft i got it working
  7. bobbles
    bobbles
    no probs, happens to the best of us
  8. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Ah that old chessnut (hence my question about protection plans). I've gone through this process several times and no joy - they're coming round tomorrow to replace the box.
    Incidentally, the operator was quite interested about it all and said it was a issue being investigated. I've previously had perfectly good recordings come up as failed, and also had problems moving between screens in the Recordings menu.
