sky plus hard drive capacity
Discussion in 'Sky Digital TV Forum' started by triumph, Jul 25, 2005.
  1. triumph
    triumph
    Feb 10, 2005
    When all the recorded programes have been deleted from the planner
    it shows only 73% free space, where has 27% gone? can the hard drive
    be reset so I can get 100%. any advice gratefully recieved
  2. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    You need to do a planner rebuild. Do the following:
    Press:
    Services
    4
    Select
    The choose the Planner Rebuild option.
    HTH
    John
  3. drdavewatford
    drdavewatford
    Sep 23, 2004
    42
    I've the same problem - I've lost about 70% of my hard drive capacity somehow.
    Will the "Planner rebuild" option delete all recorded programmes from the hard drive ?
    Dr. D.
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It shouldn't, but nothing is guaranteed with Sky+ boxes :)
  5. drdavewatford
    drdavewatford
    Sep 23, 2004
    42
    Ah well - only a bunch of my fiancee's rubbish on there anyway, so if this procedure DOES wipe the data it'll be a blessing in disguise....
