Sky plus box, no 2nd lnb signal
Discussion in 'Sky Digital TV Forum' started by tim k, Apr 2, 2005.
  1. tim k
    tim k
    I know most of you will tell me its a hard drive failure, the thing is the box is brand new and never recorded. I can pause some channels and record a couple of seconds of tv. i tried a factory reset (holding left and right navigation buttons) but after a few mins that didnt sort out the problem. my question is, can i buy a cheap hard drive (inc upgrade in size) or any other solutions.
    btw its a designer flower painted box supplied from selfridges and ive been told if i take it back i will get a standard box, losing me money.
  2. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Try using it.I have had Sky+ since Xmas.My second input spends most of its time showing a low or no signal.However,a recording seems to trigger it into life.Despite numerous dual records it has not failed yet,even though input 2 is STILL showing no signal.Try starting 2 recordings and see if input 2 is still dead.If it is,contact Sky.As its a new machine they will at least offer you free subs in lieu of any cash lost if they cannot supply a decorated box
  3. tim k
    tim k
    a google search on the subject and a quick call to sky resulted in a 10 minute software upgrade which rectified the problem, so all is well :)
