Sky Plasma
Discussion in 'Plasma TVs Forum' started by TonyITA, Jun 4, 2004.
  1. TonyITA
    TonyITA
    the sky deal on their branded 42" plasma. has anyone bought it and what is it like? Is it worth the money?
  2. diabolik
    diabolik
    do a search, there was a funny thread on this a few weeks back
    :laugh:
  3. TonyITA
    TonyITA
    very funny indeed
  4. Ancillotti
    Ancillotti
    I believe the general feeling on these boards is to avoid the Sky (Daewoo) Plasma as much as possible. It is overpriced to say the least - I would suggest looking at the Panasonic 6 series/PE30 models :)
  5. TonyITA
    TonyITA
    cheers, i will take a look at the panasonic. Good luck with Milan next season!!
  6. Ancillotti
    Ancillotti
    Thanks, but my name refers to a manufacturer of mountain bike frame ;)
  7. TonyITA
    TonyITA
    the deal inlcudes 42" plasma, 300W surround sound, alphason stand, 4 alphason speaker stands, floor/mountable side tv speakers, all with 3 year warranty for £3.5K over 3 years 0% finance..... is this not a good deal??
  8. Elvis
    Elvis
    It's all cheap re-branded stuff with a premium price. You can get better quality for the same money elsewhere. The only 'good' bit is 3 years 0% finance, if that's something you want to take advantage of. Personally I never buy on finance 0% or not.
  9. TonyITA
    TonyITA
    Elvis, thank you very much :cool:
  10. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    The plasma at any price is dubious, the daewoo is prone to banding, solarisation and all other plasma vices to a greater degree than most. For 3.5k you can get a PWD6 panny, yamaha 540 amp (500w total) 6 speaker surround, a 540DVD, all the cables, a stand for the kit, wall mount for the plasma, and a warranty, all in a well known high st chain, beginning with R. You could have it all installed from expensive folks like me for not a fat lot more, believe me it's not a good deal.
  11. TonyITA
    TonyITA
    MAW, get that feel that SKY isn't the limit and there's better deals out there. Thanks for the advice.
  12. TonyITA
    TonyITA
    what boards would I need to connection if I went for the Panny 42PWD6, I have sky box, dvd player, xbox and possible connection of PC.. the SKY Plasma came complete with multiple connections source built-in.
  13. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,516
    Kent
    +830
    do a search on Panasonic Connections because there's a million and one ways of doing it, all with relative costs and benefits. Simplest approach is a scart board and scart switch box but you may decide to use one of the JS Technology converters and you may intend on running the DVD progressive scan so requiring a component board. There is already a PC socket installed. Again do a search and find the answer closest relating to your setup!!! There's plenty to choose from...
  14. diabolik
    diabolik
    I got the Y board with my panasonic which includes a component, svideo and composite video input. I run my ntl box through a JS technology rgb to vga converter into the vga input on the plasma. I use the component input for my dvd player and svideo for my vcr. I suppose you could use the svideo for your xbox.
  15. TonyITA
    TonyITA
    what is the picture quality like going through a JS Tech rgb to vga convertor?
  16. diabolik
    diabolik
    Much better than the scart board apparently but Ive never seen them compared in person. The picture Ive got is pretty good but I consider the limiting factor to be the quality of the source marerial, so good broadcasts look great and old stuff like Uk gold looks a bit cr@p.
