Sky / Plasma / RGB Problem
Discussion in 'Sky Digital TV Forum' started by [email protected], Nov 2, 2005.
  1. nic@highgroundd
    [email protected]
    Jan 10, 2005
    182
    +3
    I wonder if anyone can offer any advice?
    We have a Sky set-top box, hooked up to our Panasonic Viera (PE30B) via scart. Some kindly person suggested to us that we try to shift the Sky box setting from 'PAL' to 'RGB', suggesting it would vastly improve the picture quality. Having followed the advice, the overall picture did duly improve, BUT, flicking through Sky channels procured a level of digital spluttering that rendered the switch unusable. (If nothing else, for the sake of our surround system, which was suffering intolerable peaks of digital squealing).
    Having sought some advice (as you would, knowing that PAL was now an unnecessary sacrifice), an el 'cheapo scart cable was cited as the probable cause. That scurrilous remark was begrudgingly accepted and thusly we invested in a 'decent' scart lead costing about 20 sheets (Cambridge Audio I believe). This was guaranteed to easily carry an RGB signal without problem.
    So anyway, it didn't work, and so I have again turned to the forums of life.
    Any ideas would be most welcomed? (and if you could bare in mind that my level of knowledge on all things tv are about 6/10). ;)
    Cheers!
  2. Glenn2
    Glenn2
    Oct 18, 2005
    59
    London BR3
    Replied to your post in Plasmas forum.
    Sky Box = Panasonic TU-DSB31?
  3. nic@highgroundd
    [email protected]
    Jan 10, 2005
    182
    +3
    Yep! - got that, thanks G.
  4. TommyT
    TommyT
    Dec 28, 2004
    52
    Glasgow
    Exact same thing happened to brother in law..same tv also. He went to a local shop and the guy offered him a lead to try out. It duly worked..and he said it is 100 times better BUT as for the price..it was more like £60.00 for the scart...he said it was that good that he bought it.
    Tommy
