Sky+ planner
Discussion in 'Sky Digital TV Forum' started by lukesurrey, Nov 8, 2004.
  1. lukesurrey
    lukesurrey
    I'm having problems with the percentage on my sky+ planner. :confused:
    If I add up all the recorded programmes and take it away from 100 it does not give me the figure in the top right of the screen and often falls far short. I've rebuilt the planner using services 4,0,1 sometimes it work and adds up correctly but more often than not it doesn't. Any ideas why this is happening and more importantly any fixes? :confused:
  2. potshot
    potshot
    Jan 31, 2004
    2,058
    63
    +184
    I just done a post saying the same thing. I wonder how many other people are having this problem.
    Mike
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    You may need to do a Full System Reset, wipe the hard drive totally and start a fresh, you will lose all your recordings so either watch them or put them onto other media before the reset.
