UrbanT
We currently have Sky+ in our living room. The garage is about to be converted into a HC room. I would like to pipe an RGB signal into a HCPC (and then into a PJ) so as I see it, I have 2 options
1) Move Sky+ box to garage, and pipe back to living room
2) Pipe from living room to garage
The question is, can I pipe an RGB signal from the living room into the garage? If so, this would be the best solution as the box is quite noisy and would be irritating in the garage.
If not, can a signal be piped directly into the PJ, a Z2, and if so what is the best connection? I'm a bit
so any other suggestions are welcome
