Sky + Picture Quality
Discussion in 'Sky Digital TV Forum' started by salmon1, Apr 25, 2007.
  1. salmon1
    salmon1
    Dec 30, 2006
    35
    Have recently bought a sky plus box, and having a few problems with the picture. Its only really noticable when a patch of the screen is moving, eg something with the sea or a river in it. The picture seems to go into little rectangular blocks. Otherwise the picture is very sharp.
    I have the Sky + box fed into my Yamaha DSPAX759SE amp via an s-video cable, then via component cable into a Toshiba TV (regular TV, not a plasma etc).
    Anybody any idea what causes this, as its massively annoying? Have had sky for years and never really noticed it before, so not sure if its something in my system set-up, or a poor signal etc
    Any advice appreciated,
  2. salmon1
    salmon1
    Dec 30, 2006
    35
    Sorry, can a mod move to the Sky + forum, cheers!
  3. reforse
    reforse
    Nov 10, 2006
    187
    +12
    Well done that man, a lesson to all the Sky posters in the wrong section.
  4. Fusewire
    Fusewire
    Jul 18, 2005
    1,617
    63
    +104
    Getting rid of the s video cable into the amp would be a good start, try using a decent scart straight to the tv and using the optical output from the sky box into the amp. :thumbsup:
    Don't forget to change the signal output to RGB in the services menu. :)
  5. salmon1
    salmon1
    Dec 30, 2006
    35
    Cheers, will give a scart a go:thumbsup: . Have read on the net somewhere it could be somthing to do with the LNB skew (no idea what it is though).
    Sent a complaint into sky, so always good to have some ammo to fire back when they come back with some scripted reply!
  6. avinitski
    avinitski
    Apr 22, 2005
    3,319
    +216
    low bit rates on some channels cause this.
  7. kbj242
    kbj242
    Sep 23, 2005
    526
    28
    +32
    Salmon - I agree with the above poster...try a decent scart lead direct to the tv...and make sure you select "RGB" from the picture settings menu in the services section of the Sky+ menu...then you need to ensure you connect the scart to an RGB-capable scart socket on the tv...Sorry if you were aware of all this beforehand..just trying to help.
  8. salmon1
    salmon1
    Dec 30, 2006
    35
    All advice appreciated!
    Going to change to a scart at the weekend as first attempt, had just changed to a s-video so I could run it through the amp. Have got the DVD through same set up though, so would have thought this would affect both? Box is currently set to RGB, although I didn't realise that about the scart input at the back.
    Got my reply from Sky saying the usual, check the cables are all correctly fitted and turn off and on again, otherwise they say it will be a problem with the dish or box.
  9. fnloud
    fnloud
    Jul 25, 2005
    75
    England
    +5
    I've just my TV replaced because of this, and it hasn't sorted it! tried new scart, and running a scart adapter with rca's and still having a problem. Started about a week ago? Going to do some more investigating at my end...
  10. salmon1
    salmon1
    Dec 30, 2006
    35
    Have tried replacing the S-Video with a scart direct to the TV, and picture is still the same. Think best bet is to get the sky engineer out as the box/dish etc is still in warranty.
