SKY+ - Picture Quality via Sky Link
Discussion in 'Sky Digital TV Forum' started by pedromartinez, Feb 3, 2004.
  1. pedromartinez
    pedromartinez
    Just had a Sky+ v1 box installed (through the £99 deal :clap: )
    Overall very happy with Sky+. The PQ on my plasma looks a lot better than through standard digibox, however, the feed to my 2nd TV (via Sky Link) has degraded quite substantially.
    Before the install of Sky+, the PQ on my TV was superb but now I can clearly see rolling diagonal banding across the screen.
    I have checked the RF settings (they are the same as I was using on my standard Digibox), have updated the Sky+ software, and have tried to fine tune my TV picture settings but still have the problem!
    Anyone else had a problem like this with Sky+ & Sky links?
    cheers
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Have you tried a totally new RF frequency instead of just trying to fine tune the existing one?
  3. pedromartinez
    pedromartinez
    Starburst
    Yes forgot to say I retuned from channel 55 to 50 with the same results.
    thanks anyway
  4. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    There must be differences between the RF modulators used in standard makes/models of digiboxes and SKY+ versions. This might explain the interfernece that has been introduced, of course it may be a faulty modulator but I would certainly look to an outside influence before considering a call out.
    I have the original SKY+ and have no problems using the TVlink.
    However last year after 4 years of usign a TVlink on channel 68 it suddenly just carried nothing, retuning to another channels solved the problem but to this day I have no idea why this happended.
    Do you get the same interference using RF1 as well as RF2?
    Do you run the SKY+ RF output through any boosters or distribution units and can you connect the SKY+ to a a telly on a short lead and see if the shorter cable eliminates the interference.
  5. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    Mine did exactly the same thing when I upgraded to a V1 Sky+ last week.
    I have the RF2 split and feeding 2 tv's.
    I moved the RF frequency from 57 to 47, then back to 57 - and also made sure the cable connections into the splitter were snug and it then worked a treat.
    Check your co-ax cable to the other TV is'nt running too close to a power cord, extension cable or something - electricity can cause that sort of 'rolling banding' interference.
  6. pedromartinez
    pedromartinez
    Techno
    Seems to make sense ( why didn't I think of that :rolleyes: )
    I'll give it a go
    cheers
