Sky+ Phantom pvr
Discussion in 'Sky Digital TV Forum' started by dazzer123, Oct 15, 2004.
  1. dazzer123
    dazzer123
    Sep 30, 2002
    402
    Stoke-On-Trent
    +3
    Hi can anyone tell me if the labgear phantom pvr will work with sky+ or does the phantom require the autoview feature which is sadly missing from sky+.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    It does require triggering by the digibox which I believe is caused by the Autoview function, with dual recording though is it that important now after all you only have two tuners and they are both used when you are dual recording.
    Phantom PVR homepage
  3. dazzer123
    dazzer123
    Sep 30, 2002
    402
    Stoke-On-Trent
    +3
    Thanks starburst yes I know I have dual record capability, basically the reason I wanted to try the phantom was that should I wish to record something for archiving I could have recorded it straight to my Panasonic e85 rather to sky hd and then down to e85 in real time it could have saved me at least 90mins for a typical movie ah well never mind.
