sky panasonic locks up
Discussion in 'Sky Digital TV Forum' started by abnett26247, Mar 6, 2005.
  1. abnett26247
    abnett26247
    Jan 2, 2005
    227
    16
    sometimes my sky box , panasonic freezes up ie pixelation locks up (only way to unlock it/correct it is to go up a channel or down and then return to the original channel. it then is ok ) lnb has been changed 3 times , so any one know what is this problem please ? :confused: :suicide:
  2. abnett26247
    abnett26247
    Jan 2, 2005
    227
    16
    any one know what the problem could be ,? :confused:
  3. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,397
    Bradford, West Yorkshire.
    +325
    What model is it? TU-DSB..
    Dish alignment OK? Signal levels? Which channels are affected? Try 504 & 507. Waddya got?
    A. Dork
  4. bigiain
    bigiain
    I had a similar problem with a panasonic box - it looked like a weak signal. I use a building distribution system and none of my neighbours had the problem. The box was around 2 years old, so out of warranty -
    I bought one of the new pace boxes on e-bay - problem solved.
    I don't recall model details - I'm just about to head out to work, so I don't have time to look them up right now - I can get back to you later if you like.
  5. abnett26247
    abnett26247
    Jan 2, 2005
    227
    16
    yes it is my bro lives 1 mile away same box but no probs
  6. abnett26247
    abnett26247
    Jan 2, 2005
    227
    16
    yes thank youb if you would please.
  7. abnett26247
    abnett26247
    Jan 2, 2005
    227
    16
    Will try channels tonight /get back to you thanks.
  8. abnett26247
    abnett26247
    Jan 2, 2005
    227
    16
    Tried both and seem ok . locks up not all the time but now and again is this what you needed to know .
  9. vgopal
    vgopal
    i have a problem on a panasonic box, everytime i go on certain channels the box freezes, only way to unfreeze is reset the box with the power switch, at the plug,
    mainly happens on e4 and some other channels,
