Sky+ Overheating
Discussion in 'Sky Digital TV Forum' started by Woodywizz, Oct 12, 2005.
  1. Woodywizz
    Woodywizz
    Aug 18, 2005
    10,934
    Manchester
    +4,303
    Has anyone experienced problems with the SKY+ box getting hot? Last night, for the first time in 2 years my box seemed to be very hot and a fan seemed to kick in for about 5 mins. Is this usual??
  2. simon100
    simon100
    Nov 2, 2004
    318
    +11
    I had the same problem with mine. I resolved it by ensuring that there was a decent space between the top of the sky+ box and the surrounding area. Basically is sits on its own on a shelf without anything on top of it.
  3. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,024
    Harrow, NW London
    +599
    aye, it should be treated like a cross between amp and computer, plenty of space needed to keep it cool.....altho if its getting extremely hot then its quite possible its on its way out, its having to work a lot harder to do the job so will eventually give up.......hopefully not for your sake tho..lol
