Sky + Outputs
Discussion in 'Sky Digital TV Forum' started by gunizzle, Jul 27, 2005.
  1. gunizzle
    gunizzle
    Hi All,
    Not sure if im in the right place here, just a quick question what does sky output picture wise?? is it just scart and s-video?? what do you think is better in terms of connection? is it worth buying a scart to component converter from somewhere to get the best out of the picture, if so any recommendations?????
    Anyone have a picture of the back of their sky box??
    Cheers!!
  2. Jacob
    Jacob
    Mar 12, 2005
    152
    Cardiff
    Had Sky + installed only 2 hours ago!
    The outputs are 2 x Scarts (both RGB I think), s-Video, optical, L&R Phono, RF. No picture i'm afraid.
    Not sure about the second part of your question. Do Scarts even have component output? If not. then I don't think it would make any difference!!
    I'm sure someone will give you a more informed response.
    cheers
  3. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    You can use a RGB Scart -> Component converter but it'll not do much with the picture quality.
    Often the problem with picture quality on Sky is nothing to do with the connection method used, it's down to the variable bit rate used by the broadcasters.
    John
  4. gunizzle
    gunizzle
    thats great, so out of scart and s-video which do you think would be better picture quality wise???
  5. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    Hard to say, s-video can look a little bit softer in my experience which some people prefer. For what it's worth, I use RGB scart to my Hitachi plasma.
    John
  6. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    With all else being equal you should expect a RGB scart to provide the better feed to the display but it may simply come down to which your own eyes prefer after tweaking the display of course.
    There are some pics of the SKY+ at Hummers new site.
  7. Astaroth
    Astaroth
    Jun 22, 2004
    2,283
    63
    London
    +117
    RGB Scart is on paper slightly better than S.Video but this can be offset by your equipment. I used the s.video slot as (1) it looks better on my Pd30 (which has known issues with RGB anyway) and (2) it allows connection through my AVR which then upconverts to component
