Sky+ Outputs to TV
Discussion in 'Sky Digital TV Forum' started by ikon66, May 9, 2005.
  1. ikon66
    ikon66
    Mar 22, 2005
    397
    Tyne & Wear
    +7
    Does Sky+ only have Scart out for the video signal? I know it has optical and phono out but does it have any thing like component?
  2. scitech
    scitech
    It has S-Video.
  3. ikon66
    ikon66
    Mar 22, 2005
    397
    Tyne & Wear
    +7
    so would that be better than a good quality scart? it's to go into a pio 435xde
  4. scitech
    scitech
    Um, I can't really answer that one as I've never used S-Video. I THINK that the general feeling is that RGB Scart is the way to go.
  5. ikon66
    ikon66
    Mar 22, 2005
    397
    Tyne & Wear
    +7
    when you say RGB scart do you mean rrgb onl and phono or optical for sound or full scart?
    sorry to sound so picky but wabt to ensure best pic possible from the pio.
    thanks for the input so far :)
  6. scitech
    scitech
    You're not going to see much difference in sound quality, if any, between phono and scart. If you can swing it then optical is the way to go.
    You're welcome ;)
    Darren
  7. Astaroth
    Astaroth
    Jun 22, 2004
    2,256
    48
    London
    +97
    There is very little difference in picture quality between RGB scart and s.video - RGB generally has the edge but some screens are better at handling s.video over RGB and this offsets the slight difference in signal quality.
    The best thing to do is try both with your screen and see which YOU prefer
  8. micks_address
    micks_address
    Nov 29, 2001
    4,446
    83
    Dublin
    +205
    sorry to butt in but does anyone using the s-video feed from sky plus got auto switching between widescreen/4:3 material working? i have a sony kv32fq86 and i think it handles s video better as a feed but when i feed the s video in - the picture no longers auto formats (i presume scart is using one of the pins for switching) pity the sky plus doesnt output s video via scart the same way dvd players do
    cheers,
    mick
  9. shaithis
    shaithis
    Feb 25, 2005
    1,638
    The Last Aerie
    +30
    SVideo will not do the format switching unfortunatly :(
    If you have a V1 Sky+ box though there is a hack to allow switching with S-Video IIRC, been a while since I read up on it though.
