Sky+ output to component
Discussion in 'Sky Digital TV Forum' started by markfraser, Dec 21, 2004.
  1. markfraser
    markfraser
    Apr 5, 2004
    63
    I want to start using the video switching on my denon av amp and to do so I think I need to convert the RGB or S-video output to component. There are a few devices out there like the ones from Keene but I was looking for some general advice - i.e. is my reasoning above sound and assuming I use good connectors and convetor, will the loss when compared to connecting direct to my tv be significant? Subjective I know but somebody else must be doing this? Also, any recomendations on convertors themselves.
  2. Family Guy
    Family Guy
    All depends what Denon amp you are using...most of them these days will upconvert any video signal to component...ie, you output from the s video on your sky+ box to an s video in and the amp will convert it and output it through the component outputs.
    I think thay did this from the 3803 on...
  3. markfraser
    markfraser
    Apr 5, 2004
    63
    My one is a 2803 which won't up-convert
  4. Family Guy
    Family Guy
    You're right mate...the 2803 will not upconvert. In that case, go for the JS Tech RGB to Component converter. It's the most expensive, but the noticeable loss will be negligeable - if any. I've installed many of these onto 42 & 50 inch plasma screens and haven't noticed any signal degredation at all.
    Make sure you go for the JS Tech one though...carry out a search on these forums and people swear by them...so do I :thumbsup:
  5. markfraser
    markfraser
    Apr 5, 2004
    63
    I'm using a 32" Loewe Mimo, so given what you say, the loss again should hopefully be almost nil then.
    Great - thanks very much fro such a prompt response.
  6. Family Guy
    Family Guy
    No problem...I'm sure it will look stunning.
  7. markfraser
    markfraser
    Apr 5, 2004
    63
    My new convertor arrives tomorrow (the JS one) and I was flicking through my instruction book on the receiver to see what I need to do to set up video switching and although the physical connection is straighforward I can't see how to get the video switching enabled - am I missing the obvious here? Is it somehow on by default or something?
