Sky + & Original Sky Card
Discussion in 'Sky Digital TV Forum' started by hektic, May 23, 2002.
  1. hektic
    hektic
    Oct 17, 2001
    114
    Midlands
    +8
    Guys,
    I'm just about to get Sky + and have a question about my existing
    sky card / box. I have used up all the credit on skybox office and have not plugged it back into the phoneline since. What I'm basically asking is: When my existing skycard gets transferred to my Sky+ box which will be connected to a phonline, will this then charge me or is the credit stored inside my original sky box which will remain disconnected from the phoneline?
    I wonder if its stored on both :( ??
    :confused:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Your existing smartcard will need to be married to SKY+ and then the SKY+ functions will need to be enabled.
    Both procedures will be done by the installer, the first using the SKY+ phone line the second by a phone call to SKY.
    As soon as the connection is made the SBO/PPV data (Stored only on the smartcard) will be sent to SKY and you will get the bill a few weeks later.
