SKY + Ordeal
Discussion in 'Sky Digital TV Forum' started by haf, Nov 17, 2003.
  1. haf
    haf
    Looking to get Sky+ installed 2moro with mirrored sub but have a couple of questions.
    Can both boxes be connected to the same phone socket ? and if so will sky connect if phone socket is in neither room
    Is the cable connected to the box from the dish the same as the connection cable uses -
    ie connections that are in place just now to be used again because sky dont do lofts
    If Sky cannot do install will they leave the equipment if I want to do myself ie just align dish leaving me to sort cable runs etc
    Henry
  2. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    I can answer one part. Yes you can connect 2 boxes to one phone socket with the aid of a double adaptor thingy. I think the can run a cable if the socket isnt close but it may be chargable.
