sky or telewest?
Discussion in 'Cable TV & Virgin Media TV' started by stephen19, Nov 24, 2004.
  1. stephen19
    stephen19
    Dec 9, 2003
    76
    Hi, Have a choice of Sky or Telewest where I am. Which do you recommend? Is one of a better quality than the other (higher bitrate, better picture/audio, etc)?
    Thanks.
  2. nabby
    nabby
    May 30, 2003
    5,270
    Surrey
    +2,124
    I'm with telewest but would dump them for Sky at an instant if I could (I'm not allowed a dish unfortunately!). Sky+ is the future from what I can tell so my opinion would be to go with that. I guess the only plus for Telewest is that you can get a pretty cheap broadband and phone package included with the tv service if you want. But from what I can tell, the tv is cheaper on SKy than on telewest.
    Nabby
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Sky - because of the facilities offered by Sky +
    Record to hard disk
    Record two programs at once, whilst playing back a third
    Easier to use than a VCR, and fantastic quality recordings
    Dolby Digital sound on Sky Movies
  4. stephen19
    stephen19
    Dec 9, 2003
    76
    Hi, Thanks for the fast reply. Is the opnly reason you would go to Sky for the plus box, or are you having problems with TW? I probably will not have the premium sports and movies channels (to begin with at least) so I would only be after a standard sky box, not the plus, and sky and TW seem to offer similar packages for the same prices.
  5. nabby
    nabby
    May 30, 2003
    5,270
    Surrey
    +2,124
    No but it's one of the main reasons. I guess it's just the fact that Sky is better value becuase there's no middle man, you get full digital functionality with the red button for the interactive digital services and a bigger choice of channels for your money.
    If you're a new subscriber I would suggest the Sky+ box, even if you don't go for one of the premium packages, unless it's way too expensive without the premium package subscription. The reason being that often the best deals are for new subscribers rather than existing ones. That way, you have the best hardware upfront and can chop and change your package accordingly (within the terms of the contract of course).
    If you're really anti-dish then TW have not given me any problems at all but given you have a choice I would recommend Sky over TW.
  6. MJ Invincible
    MJ Invincible
    Hi Stephen! I have got both sky digital and ntl digital cable TV, and I would advise you to get sky, as it is the best channel provider in the UK imo. The 2 main reasons why sky is better than cable are...
    (1) Sky is a LOT better system in terms of ease of use, reliability and quality.
    (2) If you are going to subscribe to 2 or more premium channels, there are many benefits of getting sky+, such as being able to record programmes to the hard disc for later viewing, recording up to 2 channels at once, pausing/rewinding live TV, etc. No cable operator has an integrated hard disc drive recorder at present.
  7. MJ Invincible
    MJ Invincible
    Even if you don't need sky+, the benefits of (1) above means that if you can get sky go for it, as it is the best option.
  8. Orwella
    Orwella
    Oct 10, 2004
    748
    28
    Romford
    +31
    Get neither. Spend the money on beer instead.
    But if you really have to, Sky+ is the way to go.
  9. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    I had a telewest box in one room and Sky in the other, so was able to get a good comparison. IMO the software (EPG) on telewest was awful. Very drab and much more difficult to use than Sky. I didn't think the pic was as good either, but that may have been down to the TV. Anyway, as soon as I got SKY+ multiroom I lost no time in dumping the telewest box. Just use them for phone and broadband now (which is excellent).
