SKY+ or Freeview for best PQ on plasma
Discussion in 'Plasma TVs Forum' started by EpsomJames, Nov 10, 2004.
  1. EpsomJames
    EpsomJames
    Jul 2, 2004
    176
    +8
    I'm curious which would give the better picture on a PW6.
    I'm considering buying a freeview receiver even though I have SKY+, because I'm (very occasionally) finding my SKY+ busy recording 2 channels when I want to watch a 3rd. Or when I'm dubbing from SKY+ to DVDR and want to watch something else.
    Would the Netgem iPlayer be any good using the (so I have read) component output through Scart (how does that work)? Could I connect it to the VGA on the PW6 with a JS Tech adaptor?
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Freeview appears to be better - however if you want component you have to have the Netgem
  3. spook
    spook
    May 18, 2004
    157
    EpsomJames, I am waiting for the panasonic TUCTH100, twin freeview PVR, should be out at the end of Nov for a couple of hundred quid or thereabouts,
    I have noticed that most of the progs I like to watch seem to all be on at 9pm, sometimes there's 4 or 5 on at the same time hence the extra PVR as well as Sky+
    I really must get out more :suicide:
    cheers, Spook
