sky optical - the one with red light?
Discussion in 'Home Cinema Buying & Building' started by skaps, May 24, 2005.
  1. skaps
    skaps
    Oct 31, 2004
    45
    trying to link my sky+ amstrad through the denon 500, it was suggested using optical out, whats that :confused:
  2. Steve_runner
    Steve_runner
    Mar 28, 2005
    14
    3
    Peterborough
    Just connect the optical out from the Sky box to the optical in on your Denon, check the manuals. It's a cable available from JL or Currys or online:
    Here
  3. skaps
    skaps
    Oct 31, 2004
    45
    thanx :thumbsup:
  4. skaps
    skaps
    Oct 31, 2004
    45
    which channel will the sound come from video 1, etc?
  5. johndon
    johndon
    Feb 3, 2002
    1,971
    63
    +108
    The optical in will be set to a particular input on the amp and should be marked on the back.
    For example, on my amp (an Arcam AVR300) there are optical inputs marked SAT & DVD so my Sky+ box is connected to the SAT optical in and it's that input on the amp that I select.
    HTH
    John
  6. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    If you use the optical in, the sound will come through Video 2.
    There's a pic of the rear panel hereDenon 500 rear panel Opt.In is labelled Video 2.
  7. skaps
    skaps
    Oct 31, 2004
    45
    :clap: JUDDERS AND ALL THANKYOU, PROBLEM SOLVED :clap:
