Sky+ optical out to Sony DAVS 800
Discussion in 'Sky Digital TV Forum' started by ralphdt, Dec 4, 2004.
  1. ralphdt
    ralphdt
    I've got a Pace 3100 v2 from simplydigital and plugged in a JVC optical cable from Sky+ to Sony DAVS 800 (video2). But get no output through the Sony on any channel (even ones with DD).
    Have I missed something?
    Does Composite video need to be provided through the DAVS 800 ?
    I'm guessing because the instructions say so little it should just be a case of plug the cable in and it works!
    Where would I best start to troubleshoot this as I've never used optical cables before? Swap cable? test with different input source?
    Daniel
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    need to enable optical out in sky box menu................
  3. ralphdt
    ralphdt
    Is this the screen where I change it from Normal to Dolby Digital ?
