SKY+ on NTL ? is it possible?
Discussion in 'Cable TV & Virgin Media TV' started by RedGBarn, Jul 6, 2004.
  1. RedGBarn
    RedGBarn
    Jul 6, 2004
    11
    Is there anyway I can create the equivalent of SKY+ but for my poor old NTL box. IE: is there a HDD recorder than can control the NTL box when in timer mode
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Tivo? You can buy a device to enable a tivo recorder to control a pace NTL box. 2nd hand Tivos are easy to buy.
  3. noidea
    noidea
    Jun 8, 2004
    961
    46
    +107
    for info, I signed up to Telewest yesterday and asked if they were ever bringing out an equivalent to sky+ and was told that they'd just started work on a product. No timing given, but in the pipeline...
  4. MikeHarrison
    MikeHarrison
    If/When the Philips HDRW720 HD/DVD recorder appears in the UK, it will be able to control NTL STBs with the GuidePlus EPG system.
    It has been reported that the Toshiba RD-XS32 can control the NTL STBs.
    Both the above recorders will require the use of a Red-Eye translator with some NTL STB models.
  5. scrapbook
    scrapbook
    Jan 12, 2002
    7,115
    +527
    So what are the main advantages of that over a normal HDD/DVD? I assume you can't record one channel whilst watching another?
  6. MikeHarrison
    MikeHarrison
    The only difference is the ability of the HD/DVDR to select the channel on the STB, for unattended recording.
  7. scrapbook
    scrapbook
    Jan 12, 2002
    7,115
    +527
    Is that a major issue then?
    I was just wondering as normally you can set the NTL box up to auto tune to the channels you want to watch if when unattended...assuming of course the EPG is working correctly..which is very rare..although it only has a three day event so its no good if you are away for a week!
  8. bill millet
    bill millet
    So has any UK NTL cable members here who have not gone the Tivo route achieved a minimum fuss system to recording in advance?
    I am wishing to buy a HD/DVDR, but want to get something that is easy with regards to recording in advance from my NTL Pace Di4010 box.
    If I have to use the 3 day NTL EPG, as well as the HD/DVDR EPG then so be it. But am interested to hear how others on this forum are going about it.
    Has anyone had sucess with the Philips GuidePlus and NTL?
    What about a non Tivo PVR solution with NTL, do these exist?
  9. MikeHarrison
    MikeHarrison
    GuidePlus should work, via the Red-Eye translator. DVDR80 users have reported varying success at obtaining and installing the latest version of the Philips DVDR80 firmware, which is supposed to support the NTL/Telewest channel line-ups, but it is reported to be useable even without this - you just have to set up the channel numbers manually. More info at www.redremote.co.uk/dvdr80.html
    Hopefully Philips will have got this sorted out when the HDRW720 appears in the UK.
  10. bill millet
    bill millet
    Is the Philips HDRW720 out anywhere yet?
    I see it is now on the Philips website.
    Has anyone seen a review for it yet? I vaguely remember seeing a review for it, which slated it, but I couldnt find it again. I've seen so many reviews recently that I may be getting confused with another model.
  11. MikeHarrison
    MikeHarrison
  12. bill millet
    bill millet
    Thanks :) , I'll hold out and wait and see what sort of reviews they get, and whether users confirm that GuidePlus+ works nicely with this box and an NTL box.
  13. JamesTapp
    JamesTapp
    Oct 2, 2002
    235
    16
    Bedfordshire
    I still think that today, the best option for NTL users is Tivo.
    I have had it for more than 2 years, it is superb. Even my Finance Manager thinks so. ;-)
    Why?
    1. Season Pass, I tell the Tivo what programmes I like and it records every new episode, if there is a clash between two programmes in the next three weeks it looks at alternative showing times, and reschedules if possible - otherwise it asks me what should take priority.
    2. Suggestions, Tivo learns what you like to watch, and then records other programmes when it is not doing anything that you may like.
    3. I can set up wishlists, based on Actors names, Directors names or keywords so that if I want to catch anything related on any channels, it will do so.
    4. I have the Tivo connected to the Internet, and I can program recordings from any Internet terminal.
    I rarely watch live TV anymore although if I do the pause and rewind feature is great when the phone rings! Skipping through adverts is also a godsend.
    The fact that twin tuners are not available doesn't really affect my viewing. Control of the NTL box is reliable, and I don't use the NTL remote at all.
    You can buy boxes from www.tivoland.com, as well as ebay. Customer Services are run by Sky (I called them once to subscribe).
    www.tivocommunity.com has more advice than you will ever need.
    Many friends have Sky+, and still marvel at what Tivo can do. :thumbsup:
    James
