Sky+ on my PC
Discussion in 'Microsoft Windows' started by dUnKle, Jun 30, 2005.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,159
    +2,172
    Got my MCE system running lovely now - last thing I want to be able to do now is watch Sky via it
    on the next shelf I have Sky+ whats the easiest way of getting this onto the PC so I can watch and record via MCE ?
  2. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    I'm planning on running a S-Video cable and a set of Phono - 3.5mm into the back of my PVR 150 in my MCE system. Can't see why something as simple as that won't work. If not I've sent a lot on 10 metre cables!
  3. Skunkpipe
    Skunkpipe
    Yup - that'll do it:smashin:
  4. Big_Vern
    Big_Vern
    Jan 10, 2005
    315
    +18
    I have a standard Sky Digibox (Grundig) and use exactly that setup - S-Video out to my PVR card, twin phono plugs to 3.5mm jack into my sound card and it works a treat!
  5. Stellavision
    Stellavision
    Apr 7, 2003
    2,375
    Southsea, UK
    +101
    Mine is connected via component into my sweetspot card.
  6. dUnKle
    dUnKle
    Jan 1, 2001
    15,159
    +2,172
    So will that sllow for all the record on pc functions etc ?
  7. Big_Vern
    Big_Vern
    Jan 10, 2005
    315
    +18
    Indeed it does! At the moment I'm using the WinTV2000 software that comes with the PVR150 card but I'm looking to move to TVedia when I get the rest of the bits for a dedicated HTPC.
    For playback (as I'm outputting to a CRT TV) I use an XCard and it's player but the TVedia package will bring everything together.
  8. philipb
    philipb
    Mar 6, 2002
    2,032
    63
    Swindon
    +148
    Barrie
    But not within MCE? Or do you?
    I wonder if the PMS (Plugged-in) guys are working on BDA drivers for the Sweetspot cards - SDI too?
  9. Paladine_UK
    Paladine_UK
    I am in a similar situation but I have ViVo (video in/video out) on my graphics card which comes with a dongle for svideo in.
    So I have run S-Video cable from my Grundig box S-Video Out to my Geforce 6600GT S-Video In
    However, I am unable to figure out how to see the stream. I have installed the wdm drivers and when I select he device in VLC and press ok I get nothing back.
    I would have thought that if I am using S-Video In on my card I shouldn't need a tv tuner card.
    Any help appreciated.
  10. JonMace
    JonMace
    Nov 20, 2002
    2,567
    83
    Kent
    +210
    Are you using MCE? If so you do really need a tuner although there is a hack on thegreenbutton
  11. Paladine_UK
    Paladine_UK
    No just XPPro sorry I never noticed this was the MCE forum, I found the thread in a search.
    It is bugging the hell out of me though. VLC is seeing an input but it is not able to stream it. Maybe there is some bug with the 6600GT ViVo but I can find very little info whatsoever on using S-Video In on this card.
