Sky on Demand set up help
Discussion in 'Sky Digital TV Forum' started by mjhickey, Feb 25, 2013.
  1. mjhickey
    mjhickey
    Jan 5, 2010
    63
    I want to set up Sky demand using my existing BT router, my present set up is that my BT router is located next to my PC in my upstairs study, my sky box and tv are located in my downstairs lounge, my router is set up with a netgear wireless adapter to enable wireless reception for other items in the house and reception is ok, a telephone line is connected to the sky box in the lounge, my thoughts are that I relocate the BT router and connect to the downstairs sky box using an ethernet connection, do I need to have the telephone line connected to the Router and the sky box together or only to the router in and ethernet out.
    Many thanks
  2. SirTiger007
    SirTiger007
    Apr 7, 2007
    778
    46
    +204
    On Demand only requires an Ethernet connection to your router. For full connectivity it does need the phoneline as well though.
    Another option is to buy a wireless adapter for your sky box from sky. I think they're about £20 and will be available on the Upgrade page of your My Sky. Might be easier than moving the router.
    Good luck!
  3. SirTiger007
    SirTiger007
    Apr 7, 2007
    778
    46
    +204
    I didn't mean "connectivity", I meant "interactivity" but the iphone app doesn't let me edit my posts!! I don't have my sky box connected to the phoneline and on demand works fine. You only need the phone line for buying films from the Sky Store and the services on the Interactive button.
  4. mjhickey
    mjhickey
    Jan 5, 2010
    63
    Thanks ST007 for reply, think I will go buy the box advice , for £20 not worth the bother of upheaval of the router
  5. lowmans100
    lowmans100
    Dec 20, 2006
    1,480
    +461
    I use powerline adaptors for my Sky box, no need to move anything just connect ethernet via your existing house wiring.
  6. larkone
    larkone
    Apr 21, 2006
    4,270
    134
    North Essex
    +1,182
    I would avoid the Sky wireless connector as it is very flaky - check out the Sky forums where there are literally thousands of complaints about its stability. Best to use homeplugs or search the bay for a wireless bridge
  7. mjhickey
    mjhickey
    Jan 5, 2010
    63
    Hi Guys, relocated my router to downstairs telephone line that runs to the sky box to make sure it worked ok before connecting to the box, the blue power and broadband lights came on ok but not the wireless light, had connected with dsl but already have one at the main phone socket, extention off this to sky box, at this point had the good lady jumping up and down wanting to watch tv, replaced and will try another day when she is out.
