Sky on a PC
Bulla666
Is there any way I can have a sky subscription on my PC ? ie do Sky do a card I can plug my dish into and display on my PC ? And on the same note can I use my PC for recording the stream al la Sky+ ?
Bulla
antfish77
no mate. You would require a normal sky box with RF out to a Video capture card in your pc. This would then allow you to record video directly to your pc and watch it via your PC disply.
Member 55145
no i believe you can get satellite pc cards which you can put sky cards in.
try a google search
edit:
http://www.radioandtelly.co.uk/onyourpc.html look towards the bottom.
there are other less ligitimate ways of course, but i do not do them as a)i dont have a dish and b)i dont know how
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
