Sky not true widescreen!?!?!?
Discussion in 'Sky Digital TV Forum' started by Tyler Durden, Aug 20, 2005.
  1. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,356
    Shrewsbury, UK
    +300
    I have conected up my new Benq 5120 to my Denon 3803 using a component lead. When I play a dvd I get a proper 16:9 screen which fills my projector screen perfectly, however last night watching Kiss The Girls through my Sky box I discovered that I had a slightly narrower picture which left black bars to the left and right of the image. I have heard of 15:9 ratios before but I thought sky was at 16:9.
    Can anyone help? :lease:
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,858
    Galactica C.I.C.
    +279
    It may have just been down to the way it broadcast. What channel was the film actually on? was it a sky channel or bbc through sky ect?
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The term "Widescreen" covers a multitude of sins. The standard for widescreen TV is set at 16:9 (or 1.78:1), but there's a variety of aspect-ratio "standards" used in movies varying between 1.33:1 and 2.35:1
    If a movie has an aspect ratio of 1.66:1 or 1.77:1, Sky have two choices. They can either stretch it horizontally and vertically and chop off the top of the picture, or leave it as it is with black bars down the sides. Either way, some people will be disappointed.
  4. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,356
    Shrewsbury, UK
    +300
    It seems that all channels through my sky box are sent in this format, even the menus! Is there anything I can do?
  5. dsw182
    dsw182
    Jun 8, 2003
    755
    UK
    +9
    Strange, as the menus should definitely be sent in 16:9 if it's been set.
  6. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,356
    Shrewsbury, UK
    +300
    That's what I thought. Anyone know how to sort it?
  7. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    I assume the amp is converting the SKY output to component so maybe the problem is with the connection method between the digibox and amp, w/s switching signals perhaps?
  8. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,356
    Shrewsbury, UK
    +300
    Can you elaborate further? Sorry I am not sure what this means!
  9. MacReady
    MacReady
    Jun 25, 2003
    2,465
    3
    Barnsley, South Yorkshire
    +198
    Silly question, but you do have your Sky box set to output in widescreen and not 4:3 or 4:3L ?
  10. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,356
    Shrewsbury, UK
    +300
    Yes, it is switched to widescreen.
    Just realised that it the sky box plays in perfect full widescreen through scart to my widescreen lcd. So I guess it is a problem with the convertion that the amp is doing, but god knows how to sort that out!
  11. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Scart carries a switching command to tell the TV when it is receiving a 16:9 broadcast, I don't believe this is present on s-video or RF so if you are using s-video to the amp which is being converted to component then perhaps the projector is not receiving 16:9 or 2.35:1 (in a 16:9 frame) even if the digibox is set up as such.
    Just guessing but seeing that you confirm the digibox is feeding 16:9 to another display does indicate a problem in the signal path and conversion.
  12. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,258
    Manchester
    +753
    Correct in that the pin 8 switching (0 / 12 volts) can also assume a mid position (around 5 / 6 volts) to indicate a widescreen transmission.
    The alternative way of indicating widescreen is using WSS - Wide Screen Signalling" is a flag inserted on line 23 in the vertcial blanking interval (the same "unseen lines" area that is also used for teletext data).
    Chris Muriel, Manchester
