Sky (NOT Sky+) Software Updates
Discussion in 'Sky Digital TV Forum' started by el-cid, Sep 7, 2005.
  1. el-cid
    el-cid
    Sep 7, 2005
    4
    I have recently discovered this excellent forum and have found many areas most useful. So thanks guys.
    Now, I have what is probably a silly question.
    I received the new software upodate for my Sky+ box overnight Monday/Tuesday (loving the remve red button, hating the overkill parental controls).
    But, my older ordinary Pace Sky box which is used as a multiroom option still has the old dark blue background. Should it have the new lighter blue background and presumably new software by now? If so, is there a way to force the upgrade?
    Thanks for any help in advance. :smashin:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Others have said there second boxes have not been updated, probably down to the make/model and maybe even another factor which dictates when updates are sent and activated.
    Nothing to worry about unless you want a specific option and even then you are better off waiting for the roll out to happen since a forced update won't pick up the new software if it has not been sent and it is a procedure that if it goes wrong can ruin your box.
