SKY+ Noise
Discussion in 'Sky Digital TV Forum' started by Andrew Lack, Sep 17, 2001.
  1. Andrew Lack
    Andrew Lack
    Apr 2, 2001
    20
    England
    I have a SKY+ box at the moment only working as a standard digibox due to normal installation problems (3 attempts and about 40 phone calls so far). I am concerned that there is a constant noise from the box whether on or in standby, not sure if it is fan noise, hard disk or other!! Has any one else experienced this?
  2. Jon Baker
    Jon Baker
    Jul 22, 2001
    48
    Cumbria
    Yes its the hard disk being spun all the time to increase its lifetime as apparently ramping up and down (like a in a PC) is bad. TIVO does this.
  3. Gary Palmer
    Gary Palmer
    Jul 17, 2000
    333
    16
    It's the fan. When mine was installed I asked the engineer to check. He called Sky and they admitted it was the fan. The stupid thing is that it stays on even when the box is on standby - I guess it records at any time....
  4. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Gary<br />Have you checked to see if the fan is running?<br />The reason I ask is that my fan never seems to run.I not sure if it's broken.The box hums and gets quite warm even when it's been on standby all night.<br />I would appreciate it if you could confirm if you fan is spinning and is it going all the time?<br />Thanks<br />Simon
  5. Paden
    Paden
    Jul 27, 2000
    578
    +23
    Hello all, I checked out a demo box on display in Comet & the fan wasn't running on thta one.<br />Cheers.
  6. xyznicko2577
    xyznicko2577
    The noise is the hard disk spinning and the fan only kicks in at internal temperature of 48 degs.celsius
  7. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Thanks Phil and Paul
    [ 19-09-2001: Message edited by: johnson ]</p>
