Sky+ newbie
Discussion in 'Sky Digital TV Forum' started by jinkyjim, Jun 14, 2005.
  1. jinkyjim
    jinkyjim
    Feb 23, 2005
    252
    County Durham
    +9
    hi,
    i'm on the normal sky, with the premium channels and i would like sky+,
    is it just a case of buying a sky+ box and swapping it for the sky digibox
    or do i need to inform sky, or do i need a new contract from sky for sky+.
    i saw a pace sky+ box for about £144 is this a good deal when the box
    is £200 plus £60 fitting from sky?? i dont need multiroom by the way.
    thanks, jim
    the website for the pace sky+ says is a Quad LNB Required, how will i
    know if i need one or not ????
    thanks, jim
  2. Bluevanman
    Bluevanman
    If you buy a box you will need to also get a quad lnb,get someone to fit it and run the extra cable required for the box. Then you need to phone Sky and get them to pair the card to your new box and activate the record facility.
  3. jinkyjim
    jinkyjim
    Feb 23, 2005
    252
    County Durham
    +9
    OK thanks Bluevanman, my sky+ box is on its way.
