sky new record!
Discussion in 'TV Show Forum' started by dennis, Oct 11, 2004.
  1. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    is this a new record for sky?,the programe"black sky race for space"started at 21.00 then cut for an advert break at.....21.04!.
    un :censored: believable! :mad:
    Implied swearword removed [by Garrett]
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Thanks for the post, looks an interesting program:)
    I suspect it would also be a new record for NTL and TW as well then:)
  3. lee789
    lee789
    Nov 21, 2003
    441
    +3
    I've seen this on a few shows, a US thing. Its so you're captive when they play it.
    Advert breaks between shows don't get as many viewers because it a tea break/toliet stop or whatever, 5 minutes in and you'll stay put. Twenty minutes in it another break opportunity.
    The thing that gets me with this is that the viewer directly pays to watch sky :confused: , fair enough with ITV they rely on advertyising revenues :rolleyes: .
  4. Gary D
    Gary D
    Jan 9, 2002
    7,772
    +827
    Just think, YOU pay for that :D
    gary
  5. zantarous
    zantarous
    Dec 11, 2002
    1,181
    63
    +221
    But you still get the same number of breaks regardles of what time they happen?
  6. MonkeyBoy
    MonkeyBoy
    Aug 4, 2000
    115
    Didcot
    +10
    Sky One did this on the new Simpsons last sunday, but they only had the one ad just at 5 mins in.
    Steve
  7. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Over a 24 hour period you do.
    A small loop hole allows broadcasters to bias their ad breaks and duration in timeslots that they see fit while reducing the adverts in off peak time.
    Personally I would be happy if SKY got rid of the final ad break in a 1 hour timeslot, come back from the break for 2 minutes of programming and the end credits (which are then talked over).
  8. HMHB
    HMHB
    Nov 11, 2001
    25,615
    Nottinghamshire
    +3,967
    I'm sure the ad breaks are getting longer, every time I switch over to UKGold there are adverts on, well 9 times out of 10 there are anyway.
  9. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Perhaps you channel surf during an ad break and most of the other channels sync their breaks with eachother and it can look like a whole EPG full of advert channels:)
  10. miniman
    miniman
    Apr 14, 2003
    567
    Birmingham
    +7
    Just got sky+ :clap: . I record almost everything now and just skip past the adverts. Well worth £99
  11. lee789
    lee789
    Nov 21, 2003
    441
    +3
    Usually they sync with programmes with adjacent channel numbers, so to avoid them move quite a way from the progamme you are watching and you've a chance of channel surfing whilst avoiding adverts. (this is what I was told by a marketing guy)
