Sky netgear router acting up....
Discussion in 'Sky Broadband' started by ensyed, Jan 23, 2008.
  1. ensyed
    ensyed
    May 25, 2006
    675
    +6
    Recently my Sky broadband router has started acting up. It either slows down or stop working and I have to unplug and replug it. In addition, sometimes I suddenly get an error "IP address....." and the internet wont work even though I have 5 bars in the wireless connection. Again I unplug and replug in the router to fix it.
    This is getting pretty annoying.
    Is it bc the router is always plugged in 7 days a week. Does it need a rest? It is 15months old.... Should I ask Sky for a new router?
    Thanks for any help:confused:
  2. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    Sounds like you may have an SNR problem - check the router stats at 192.168.0.1 and let us know what your line stats are.
  3. bluedude1875
    bluedude1875
    Jan 23, 2008
    25
    4
    south birmingham
    i have sky with net gear router, mine plays up if i leave pc in standby! i can never get an internet connection when i re-start! always have to do a repair! grr
  4. WildeKarde
    WildeKarde
    Jul 29, 2004
    4,904
    2
    Glasgow
    +922
    I had the same problems.
    Spoke to Sky who checked the router and advised it was errors on the data - the numbers of error gets so high that it slows your speed to 0.
    Basically they lowered the max speed on the router to 12.5mb (I only get about 10.5mb usually) and since then it has been almost perfect (had a couple of occasions I had to reboot)
    Speak to sky and they will check if you have loads of errors
  5. matt11689
    matt11689
    Feb 7, 2008
    3
    Hi, I was having the same problems, It seemed the router was getting very hot when lying flat so I used the stand the router came with the stand it up verticly.
    This competely fixed the problem.
    Matt
  6. Xabi17
    Xabi17
    Aug 9, 2007
    414
    +16
    The Netgear DG834GT?
    Could you post your line stats? (under 'Statistics')
