Sky Multirooms
Discussion in 'Sky Digital TV Forum' started by marky1975, Aug 15, 2005.
  1. marky1975
    marky1975
    Dec 27, 2004
    65
    romford/essex
    Just a quicky
    i have sky+ is there any way of putting my old sky box in another room and get the free channels. i take it i must get a quad LNB. as they dont do 3 way.
    does it work like that.
    thanks very much.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Yes, subscribe to multi-room. £10 a month extra, and you get another card with all the channels enabled from your first subscription. You'll need a 4 output LNB which will set you back about £25, and some cable of course.
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    I you only want the "free" channels then you don't need multiroom just a "freesat" smartcard which is a one off cost of £20 from SKY. This allows you to view the FTV channels and of course all the FTA channels, without it you will only be able to watch the FTA channels.
  4. marky1975
    marky1975
    Dec 27, 2004
    65
    romford/essex
    ok thanks very much
    i will enquire about this card
    Mark
  5. marky1975
    marky1975
    Dec 27, 2004
    65
    romford/essex
    i take i can use this card on my old digi sky box but will have to get quad Lnb as i have sky+ on main TVl.
  6. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Yep you will as Nick_UK says require a Quad LNB to provide another independent feed to the second digibox.
  7. marky1975
    marky1975
    Dec 27, 2004
    65
    romford/essex
    lovly thanks very much indeed star and nick
    Mark
  8. hog
    hog
    Jan 15, 2005
    380
    28
    +36
    hi
    if you already have sky plus, you should nt need to buy a quad lnb , as one should have already been fitted when you had the sky plus done, so you could just take a ct100 type cable from the lnb to your choosen room, and fit your old box..
  9. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    SKY for a while used Twin LNB's for SKY+ only installs, that was discontinued and only Quads used now, better reliabilty/compatability and future proofing.
  10. marky1975
    marky1975
    Dec 27, 2004
    65
    romford/essex
    even better
    do they mind selling these fresat smartcards do you ring normal sky number??
    thanks
  11. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    The website is here. and tells you everything you need to know:)
  12. marky1975
    marky1975
    Dec 27, 2004
    65
    romford/essex
    thanks star
