Sky Multiroom
Discussion in 'Sky Digital TV Forum' started by piddy, Apr 13, 2005.
  1. piddy
    piddy
    How can I connect the second feed from Sky Multiroom to a PC?
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    You can run a cable from the RF2 output on the second box to a TV card on the PC - at least that's how I do it. You need to enable the RF output which can be done IIRC by pressing Services, 4, 0, 1, Select on the remote.
    HTH
    John
  3. piddy
    piddy
    Thanks. Any suggestion as to a good TV card. It's to go into a Dell Dimension desktop.
  4. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    I picked up a cheap Packard Bell card from PC world - does the job for me. I view the pics through DScaler on the PC which does a good job of improving picture quality so it's good enough for a 19" LCD
    John
  5. GrahameD
    GrahameD
    Feb 3, 2005
    329
    Baldock
    +4
