ExSkyEnginner
Most forum users will be well awear of Skys Multiroom offer - you have a Sky subscription and pay an additional £10 per month you can have an additional viewing card that gets the same programmes as your existing card.
However, one of the conditions for the multiroom "mirror card" is that BOTH of your Sky Digiboxes must be connected to the same phone line. This is sky's clause to ensure both boxes are in the same house, and you havent given the box to your mate and split the cost!![/FONT]
But its a bit more than just having your box connected to a phone line, sky do send box callbacks at random times, miss 3 call backs and they will try to bill you for 2 seperate sky subscriptions and send an engineer to see if there is problem with the box/phoneline![/FONT]
]Now i was thinking this might work!! Somethin available in the states (but apparenlty works world wide) called magicjack!!
(google magicjacks, and then hacked/spoofed magicjacks)
Its an usb phone jack!! Plug into you internet connected pc and then plug the sky phone lead into it!!
These can be magicjacks can be hacked so you can have the caller id of any phone number!! Do a manual call back, and it may fool the sky system?!
]In theory i think it will work, but its completedly untested!![/FONT]
Also i know this will bring up legal issues!! i would like to ignore that as i have done nothin wrong...i just thought of a work around for sky multiroom, which could be used in the one property that doenst have handy phone points!!!
So i was thinking, buy this, change the number to the number the box is registered to; and once a week do manual call backs to sky from the box that sint connected to the registerd phone number!!
