Sky multiroom - phone line hell!
Discussion in 'Sky Digital TV Forum' started by stanleyntl, Sep 6, 2004.
  1. stanleyntl
    stanleyntl
    Dec 6, 2003
    806
    28
    Worthing, Sussex
    +44
    How can multiple sky boxes be installed when only the main box can practically be connected to the phone line?
    I.E. how to avoid/bend Sky's demand that all boxes be connected to a phone line . :devil:
  2. pinatubo
    pinatubo
    You need telephone extension lines installed - at your expense I believe.
  3. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    The sky installation will come with a splitter/double adaptor,much like seen here :-
    http://www.run-it-direct.co.uk/RJ45VoicePrivacy.htm
    The picture on the left shows a quad adaptor.
    You can have as many extensions as you like so long as the REN (Ring Equivalence Number) of 4 is not exceeded. Fitting telephone extensions is not hard, when i worked at Sky there was no cable length limit on the telephone cable installed,i think this has now changed so it is the customers responsibility to make sure a telephone socket is nearby the TV........
