Sky multiroom-no signal
Robbie09
i have 2 boxes both normal sky boxes both made by thomson 1 downstairs 1 upstairs
the downstairs 1 over the last 3 months has been losing signal on and off might work for 3 days then off for 4 and so on
checked all the connections done all the re-sets myself and over the phone to sky
they want to charge £65 for an engineer but before i go down this ally want to check you knoledgeable lot on here :smashin:
I'd say to check the f connector on the back maybe it has workied its way loose when you pull it out to dust or something simular sounds like a connection problem, either that or it maybe the box starting to fail
oosyadaddy
try swapping the boxes over and see if you get the same box showing no signal, that way you know if its the box etc..
