Sky multiroom DIY help
Discussion in 'Sky Digital TV Forum' started by JD GTE, Feb 1, 2005.
  1. JD GTE
    JD GTE
    need some help
    just got a new house & there is all ready a dish on the house for Sky but we want to run 2 seperate box's
    now i need to know how sky multi room is set up. is it just a case of splitting the the signal from the dish into the two box's or is it a bit more complicated than that
    when we rewired the place we have put in digital standared coaxal cable for getting the signal from the dish to the living room & 1 of the bedrooms where the 2nd box is going & both of these terminate in the loft where the cable from the dish comes in
    Any help would be really appriciated
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    It is possible to run two digiboxes by simply spiltting a single LNB feed but it is not a practical solution due to the way the digibox tuner needs to control the LNB when selecting the channel required.
    The cheapest option is to replace the single output LNB with a dual or quad LNB, these have multipule independent outputs each of which can be connected to a digibox and give the full channel selection without interferring with eachother.
