Sky multi with Quad LNB question.
Discussion in 'Sky Digital TV Forum' started by pieguts, Mar 15, 2006.
  1. pieguts
    pieguts
    Dec 4, 2005
    155
    If I change the lnb to a quad/dual then plug it in to a sky box,can I leave the box in the attic space,run a cable,and use some kind of eye in order to change channels .
    I have sky in the living room,which is also piped from the extra output to our bedroom,controling via an eye.I have just got hold of a sky+ 160 box and would like to use it in the kitchen without having the box in the kitchen.
  2. triplea4uk
    triplea4uk
    Jan 12, 2002
    2,018
    48
    Northants
    +85
    to use sky+ features you have to have two cables from lnb to that box also subscribed.
  3. pieguts
    pieguts
    Dec 4, 2005
    155
    I am not going to use the sky+ features,I am only going to use it as another normal Sky box.
  4. triplea4uk
    triplea4uk
    Jan 12, 2002
    2,018
    48
    Northants
    +85
    you need a sub then again unless you just use it as free2air which thats just a waste of sky+ box
  5. pieguts
    pieguts
    Dec 4, 2005
    155
    Yep im going to use it as free to air.I only paid £30 for it,so i may as well use it and it is only for the wife to watch in the kitchen.
  6. triplea4uk
    triplea4uk
    Jan 12, 2002
    2,018
    48
    Northants
    +85
    I would say put sky+ in your lounge and your other box for kitchen add the extra cable to lounge for Sky+
