Quantcast
Sky - moving flat within same block
klnc
Guys,
Quick question for you if you don't mind....
I'll be moving flat within the same block - communal dish on the roof - in the next week or so. Are there any issues I should be aware of when informing sky of the move. I am assuming, since the feed goes to every flat, I can just unplug it in my existing flat and plug it in again once moved. The telephone number will be the same, although, it's way out of its 12m contract period anyway.
Other concern, is whether I;m obliged to sign another 12m contract as part of the move? If so, I may just not tell them about the move, as it's a friend who's buying my flat in anycase.
Anyone with experience of this?
AV Junky
Originally posted by klnc
Guys,
As long as your telephone number is the same, shouldn't be a problem. They'll need your new address to get the billing correct of course. Should be no need for a new contract, as no installation work required and no equipment needs to be supplied.
