Quantcast
Sky Movies Pin Code Request problem
CatManDo
Hi all,
I've just had Sky Movies added onto my account. The problem is on any movies rated 15 or over I have to input my pin code.
I've gone into Parental settings and the Family Setting is set to off,
Also on the Channels tab I've checked and also pressed blue to turn off any channel restrictions.
I'm a bit confused as it also does it on my multiroom box.
Anyone got any ideas please?
Thank you
davemurgatroyd2
Unfortunately this cannot be turned off if you are watching pre-watershed (times vary according to "age" certificate) - OFCOM legal requirement
