sky movie channels sound
Discussion in 'Sky Digital TV Forum' started by systemsdead, Mar 22, 2005.
  1. systemsdead
    systemsdead
    Jan 19, 2005
    7,939
    grimsby,canada
    +1,649
  2. Stellavision
    Stellavision
    Apr 7, 2003
    2,286
    Southsea, UK
    +96
    Sky Movies 1,2 and 3 broadcast a lot of films in Dolby Digital 5.1.
    For the remainder it is Dolby Surround.
    5.1 is of course only obtainable with Sky+
  3. marty123
    marty123
    Mar 15, 2005
    180
    +3
    Your if i am right, which i am sure i am, all the sony digital boxes have 5.1 out on them! That's why i bought mine!
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Some Sony Sky boxes were Dolby 5.1 capable, but the firmware to make it possible has never been released, and isn't likely to be, since any change of mind by Sky towards these boxes would affect Sky+ sales.
  5. chillo
    chillo
    Sep 15, 2004
    733
    Northern Monkey!
    +25
    i have sky+ and have not seen my reciever output anything in Dolby dig yet, just PLII
    when watching movies on sky movies 1,2, or 3
    i have it connected to my sky+ via optical lead (Toslink) etc and settings enable in the sky+ menu!!
  6. Stellavision
    Stellavision
    Apr 7, 2003
    2,286
    Southsea, UK
    +96
    The broadcast needs to be in 5.1 and not all of the movies on 1,2 and 3 broadcast DD. it will tell you in the info if it's DD or not.
    If the film IS broadcasting in 5.1, so long as the Sky+ box is connected to an appropriate surround sound amp via optical and DD is enabled in the Sky settings everything should work fine.
  7. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    The amp should recognise a DD audio stream but make sure the amp is also "looking" at the right input for the selected source:)
  8. fuzzybee
    fuzzybee
    Apr 27, 2002
    1,477
    Chesterfield town of the crooked (Spire)
    +72
    Then somewhere along the line something is not setup correctly, check your amps settings as you should get DD from quite a few films :lesson:
  9. sinbrad
    sinbrad
    Must agree on both points above. sony boxes do have the optical out but it not enabled for DD and my Yammy DSPAZ1 recognises the DD movies from Sky as soon as one is shown :)
  10. Family Guy
    Family Guy
    Are you sure the settings are enabled in the Sky menu? This is the first thing I would check. The common mistake is that people press BACKUP after making the changes rather than going down to SAVE NEW SETTINGS. If you don't do this, then the settings will stay as they were...
    Other than that, the input you are using on your amp may not be enabled for digital in...
  11. graham w
    graham w
    Fed an optical cable from digibox to Denon 3802,what a difference!!
    Tried the same thing in another room from another Sky+ box to a Pioneer XV-DV77 and nowt!!
    Anyone know if the pioneer has an option to change to optical in? :lease:
