Sky+ mirroring
Discussion in 'Sky Digital TV Forum' started by warne, Aug 1, 2001.
  1. warne
    warne
    According to the "news" item posted yesterday, your existing box can be used in tandem with a Sky+ box for full access in another room for £12.<br />To quote Sky :"£12 is a flat-rate fee to mirror your existing subscription on the second box".
    The question is, if you only want the free-to-air channels in another room, not your full subscription, will you still have to pay £12?<br />And how is the second box connected? Is it via a wireless link similar to that already available from Sky, or does it have to be hardwired?
  2. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    The mirroring is all done in the Sky card. i.e the second box and card you get will be enabled for whatever package you already have.<br />There is no physical connection between the two boxes.
    The £12 rate only makes sense for anyone paying more than £12 for their existing, first subscription.
    Otherwise you would just buy a second box as per today.
    You wouldnt mirror a box with only FTA, you would just buy another box and get a FTA card for that too.
    On the other hand, I understand that the 2nd box costs only £215 with the £12 sub (or you can keep your existing one when upgrading to Sky+). Which is cheaper than buying one normally I believe
  3. warne
    warne
    But presumably both boxes run from the same dish/LNB - so the physical connection is at the dish rather than on the sky+ box? It would make little sense having a separate dish for each box.
    Or is the "mirror" offer totally separate from Sky+ (which the previous message would seem to imply)?
