Sky+ memory query
chard
Joined
Dec 12, 2002
Messages
398
Reaction score
Points
50
I have just noticed that my Sky+ box is showing only 88% memory free, even though there are no programmes currently stored :confused:
I even turned off the 60min rewind, which made no difference.
There are about 15 programmes waiting to be recorded through the series link.
any suggestions ?
By memory you mean the hard drive capacity?
I would have thought it was the IR reserved space, perhaps the box needs to be rebooted for the indicator to make sense. It could be a corrupt file system though, if you have no recordings to lose then do a full system reset, it will wipe the hard drive back to it's default setting. I expect that will sort out the useage indicator, then just add your series links again.
Services
4
Select
7
many thanks ..I did of course mean the hard drive .
I will give the above a try, cheers !
did the above and it worked ! brilliant, thanks for the tip, it reset the hard drive capacity to 100 % !
LG G4 OLED Best Picture Settings Out Of The Box - Filmmaker Mode!
Back
