Sky Man
MrTibbs88
Established Member
Got the Sky engineer here as i type, he's installing HD multi room.
He has alot of can do's and can't do's, i had to go into the loft and pull cable through from the dish to the upstairs room. He's also bolted his ladder to the house and looks like he's more fit for climbing Everest with the amount of PPE on.
Hopefully he's finished the install before the Lions tour. I don't hold out much hope at this rate.
digitaldecks
Established Member
ask him if he can fit you an 8 way LNB.... if hes got one in his van ... comes in very handy!!!
D
Deleted member 221953
The PPE is a requirement of the company, if he falls and gets injured or worse how would you feel then?
Someone in my company died this week due to a fall from height.
There is always a reason for can and can't do's!
Just let him get on with it safely.
Martin
Stuart Wright
AVForums Founder
Staff member
If you don't want bolts on your house, you have to get an independent installer to do it for you.
njdbaxter
why would he bolt a ladder to the house
SKY installer put my dish about 4m high on the side of the house and drilled a hole directly below it into the first floor living room. Then attached a second cable to the outer wall which went round to the back of the house at the far side, at 4m high, then straight down to the ground floor and into the playroom, using a standard ladder and very little PPE.
Trollslayer
Outstanding Member
I think EM told you (post #6).
Some jobs are simpler than they appear, some are worse.
It's not like you are paying by the hour.
paulyoung666
Congratulations , now consider the implications if the ladder had slipped , I came off a ladder at first floor height , trust me it really does hurt and no you can't do a thing about it ...
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
