sky+ man here now, what about relocation?
Discussion in 'Sky Digital TV Forum' started by obiwan, Oct 6, 2003.
  1. obiwan
    obiwan
    Nov 22, 2002
    319
    Devon
    +5
    I thought the engineer would relocate the existing box.
    Im not taking out extra sub, but should he still move existing box upstairs??
  2. raigraphixs
    raigraphixs
    Jul 11, 2001
    51,225
    +16,033
    I have the same question too,
    Would i need to ask when phoning sky for skyplus installation, that i want an extra cable put on?.
    I want Sky+ installed. This comes with a quad LNB?, does sky+ only need 1 cable from dish to box?
    Will the engineer put another cable on to run my previous box.?, how much extra is that?
    regards
    rai
  3. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    I believe but not confirmed that SKY charge £25 to relocate the existing digibox, you have to request that at the time of the SKY+ order otherwise the installer should just do a straight replacement. Of course if you make it worthwhile the installer "might" relocate the exisitng digibox for a few quid less than SKY charge.
    SKY+ requires two LNB feeds, that's two single cables or a shotgun cable (Two cables in a single sheath).
  4. raigraphixs
    raigraphixs
    Jul 11, 2001
    51,225
    +16,033
    1. Thanks for that, and the sky+ comes with a quad LNB?.
    2. So can the engineer put a in shotgun cable? (Two cables in a single sheath).
    to the sky+ box, then nothing needs to be done, as i want to leave my existing box where it is?
    rai
  5. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    If you order it from SKY then the installer will bring the Quad with him, it was including in the retail packaging when SKY+ first launched but that is not always the case now so if you buy retail (high strret/independent) it is something you will need to confirm before purchase.
    Yes the shotgun cable should be a option available to the installer, it is suitable for shorter cable runs, he also has the option of replacing the dish if he considers it to be damaged/worn.
    So yes if the installer puts in a shotgun cable alongside your existing single cable both the existing digibox and the SKY+ can be fitted side by side.
  6. obiwan
    obiwan
    Nov 22, 2002
    319
    Devon
    +5
    Engineer seemed to be OK.
    He left the existing cable and ran another alongside it.
    He said the picture quality is better that way.
    Also, I now have a quad and if I were to run a new cable from dish to old box would I have access to all channels???
  7. raigraphixs
    raigraphixs
    Jul 11, 2001
    51,225
    +16,033
    Thanks for all your info. I have now order sky+, and await for the engineer to call me next thursday.
    Then i can tell him I want a shotgun cable put on with a quad lnb, hopefully he will not have any rejection to doing this. But sometimes things never go smoothly!.
    Also sky said, only v2 boxes are now installed.
    ta
    rai
  8. bighal reloaded
    bighal reloaded
    May 18, 2003
    24
    You will need a mirror sub to watch the same channels on the old box.
