SKY & MAGIC EYE
Discussion in 'Sky Digital TV Forum' started by patmyhead, Mar 18, 2005.
  1. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    HI
    I have the pace minibox in my motorhome :)
    i have turned the rf on in the menu but i get no response from the pace using the eye :thumbsdow
    as the minibox does not have two outputs is this why the eye don't work :(
    if this is the case what other way can i control the minibox by remote as it is kept in a cupboard
    Pat
  2. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    any ideas?
    Pat
  3. JayCee
    JayCee
    Jan 20, 2004
    22,332
    Lanarkshire
    +2,328
    What is the model no?
  4. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    hi
    Pace Minibox (1000) (Pace 1000) is the model it can run off 12 volts so ideal for use in the van also its very small size is the reason why i got it
    Pat
  5. JayCee
    JayCee
    Jan 20, 2004
    22,332
    Lanarkshire
    +2,328
    Does the led on the Tvlink eye illuminate?
  6. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    no i have tried two eyes in case one was broke
  7. JayCee
    JayCee
    Jan 20, 2004
    22,332
    Lanarkshire
    +2,328
    Get a known good one and plug it directly into the rf out socket........if it is definately switched on in the setup menu there should be 9v coming out of the rf out socket and the led should be lit.........if not get someone that can use a multimeter to check if the 9v is present........if not the minibox is faulty.
  8. kennysatman
    kennysatman
    Mar 3, 2005
    if the box only has 1 RF output you will not be able to use the tv eye as no voltage goes to that rf output. :(
  9. JayCee
    JayCee
    Jan 20, 2004
    22,332
    Lanarkshire
    +2,328
    Wrong.... that particular model has 9v available at the Rf out socket according to the manual. :D
  10. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    thanks for help guys :thumbsup:
    got it working :D
    it was would you belive two faulty eyes :eek: i popped a third eye in & it worked straight away :clap:
    Pat
