Sky + lost recording
Discussion in 'Sky Digital TV Forum' started by scoobydave, Oct 10, 2004.
  1. scoobydave
    scoobydave
    Hi folks
    First post on here so i apologise if this has been covered before. We have had Sky + for about 2 weeks now, upgrading after our old Amstrad digibox died. Sky + has been working fine untill last night when we tried to view a programme we had recorded, the box refused to play it back even though it had it listed as recorded we also noticed that where it normally says how much space has been used by that particular recording it says 0% :confused: .Giving that up as a bad loss i deleted the programme but wasn't given any space back on the hd.Thing is my sons been merrily recording all the international football some of which have also been affected by this all saying 0% used, so on deleting them to i still don't get the space back so with only about 3 working recordings about 2 hours in total my hd is 47% full :confused:
    Any ideas
    Thanks Dave
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Well I would recommend a Full System Reset, which wipes the HD and gives you a clean slate to work off of but you lose all the good recordings as well.
    So to start with do a Planner Rebuild which should reclaim all the "missing " HD capacity and leave all the existing recordings intact.
    On the remote.....
    Services
    4
    Select
    That takes you to the "hidden" setup menu.
    Choose option 7 (Planner Rebuild) and let it do it's thing.
    As will all things you do this at your own rsk:)
